Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
2007 Caliber various problems. Help?
Old Jun 20, 2007 | 06:57 PM
miragegworks's Avatar
miragegworks
Default 2007 Caliber various problems. Help?
I have an 07 Caliber SXT with the CVT and am having some seemingly random and unrelated issues... maybe someone out there can help me?
1) Yesterday as I was driving along I noticed my odometer changed from the mileage to FUSE. I assume that means the fuse is blown, but it doesn't seem to have affected anything else. Does anyone know where the odometer fuse is? It isn't in the owners manual.
2) I am having trouble keeping front rotors on the car... the dealer first blamed a front end vibration on the badly cupped tires (at 9000 miles ?!), but after I replaced them they then blamed bad rotors which of course by then were out of warranty. Anyone else having rotor issues?
3) This CVT has absolutely no pickup at all and I nearly got creamed a couple of times getting on the highway. Is there high performance software to change this? I understand that the Nissan Altima has the same CVT so I test drove one and MAN did it ever take off.
All help is greatly appreciated, before I drive the thing off a bridge.
Old Jun 20, 2007 | 11:01 PM
bigtsr's Avatar
bigtsr
Default RE: 2007 Caliber various problems. Help?
If your Caliber is lousy in the 0-30 mph zone and was built prior to April 28,2007
there is a TSB# 18-031-07 covering a performance and sluggish performance
software update,it also improves mpg,I had mine done and the difference is
amazing.
I am not familiar with the FUSE indication however I only know that the power
distribution block under hood drivers side contains the ones that I have seen,
possibly pop the cover and check for poorly seated fuse.
The rotor problem could be poor quality parts or a result of your driving
habits only you can determine if exceptionally hard use is responsible,I have
only seen 2 other posts about bad rotors and both were replaced under warranty.
Old Jun 21, 2007 | 01:50 AM
Dodge Tech's Avatar
Dodge Tech
THE FUSE issue is for the IOD fuse under the hood PDC look for a green fuse in a white holder that has 2 in there push down on it all the way some people dont push down on then all the way when they PDI them and they wiggle up.
Old Jun 21, 2007 | 02:00 PM
Jib01's Avatar
Jib01
ORIGINAL: bigtsr
amazing.
This is a surprise about the April 28, 2007 build. I was under the impression that this was taken care of before the end of 2006. Does this have to do with the Altitude problem and the car being sluggish coming done from high altitudes ? I purchased my car in January 2007 and asked the chief mech if there were any other service bulletins for my car and he said no. I just have 2000 miles on it and will not see the dealer until Nov 2007. I will check at that time about that service bulletin. BTW, where did you find this information ??
Regards
Jib01
Old Jun 21, 2007 | 03:49 PM
dragon8master's Avatar
dragon8master
No, if your car was built before April 28th, you NEED to get this TSB done. Because, yes, the difference is just amazing!
Old Jun 22, 2007 | 12:36 AM
TUNDRA_schumacher's Avatar
TUNDRA_schumacher
They did it to ours when we had our last oil change. It's like a completely different car now.
Old Jun 22, 2007 | 01:28 AM
bigtsr's Avatar
bigtsr
The TSB is availiable on several different forums specifically
caliberfoumz.com in the TSB forum,I would post it here
but this forum does not support PDF file uploads.
