Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Heads up on a potential Fuel Gage Problem
Old Jan 3, 2008 | 01:50 PM
Jib01's Avatar
Jib01
Default Heads up on a potential Fuel Gage Problem
I found out this minor problem while in San Francisco while parked uphill during a cold evening.
I had a full tank leaving San Mateo and it is only about 30 or less miles to SF. When I got in the car to return the gage said 3/4 full. It was like in the cold weather the indicator in the tank froze or locked up. As I continued to drive it seemed the gage got back to normal.
I was wondering if anyone back East in the cold was experiencing problems with their gas gages ??
Regards
Jib01
Old Jan 3, 2008 | 08:12 PM
TUNDRA_schumacher's Avatar
TUNDRA_schumacher
Default RE: Heads up on a potential Fuel Gage Problem
Odd. Maybe because it was parked uphill?
Old Jan 4, 2008 | 05:02 PM
dragon8master's Avatar
dragon8master
Yes, when you park the car faced uphill, the gas gauge reads low when you start it back up, and vice-versa. Ours is always parked facing downhill and reads high when we start out, then it goes down to where it should be after we drive a couple miles on leveler roads. I've never owned a car that didn't do this, and actually had one that read the other way around, low facing downhill and high facing uphill. And I imagine that those steep hills than San Francisco is known for would exagerate this behavior, so you have nothing to worry about.
Old Jun 8, 2008 | 10:06 PM
Caliberman71's Avatar
Caliberman71
Yes, I live in Ohio and the fuel gauge does this. It take periodic readings and sets for a bit at that point. I was told it is normal. At first I was POed about it, but it does correct itself, so... I hope this puts your mind to rest.
