Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
'07 Tach install help!!
Old Jan 8, 2008 | 05:01 PM
Fixzit's Avatar
Fixzit
Default '07 Tach install help!!
I just bought a '07 from the Marshalling center here in MI (and I love it!!) This thing is a completely stripped SE, the only 3 options it has is Air, Cruise and a tonneu cover!! I would like to install a tach, possibly on the A-pillar;
Do I need a tach adapter?
What is a tach adapter?
Can I hook it to the factory tach wire?
What color is and/or location would I find the tach wire?
Thanks!!
[sm=gears.gif]
Old Jul 26, 2011 | 10:13 AM
Spamer's Avatar
Spamer
Thumbs up wiring tach and shift light caliber srt 4
I have an srt-4 2009, but i think it's the same for all dodge.
To hook a tach, it's soooooooo simple, but take 2 hours to complete.
First: you need an adaptor like the Autometer 9117
2: the wire that you need to hook your adaptor to, is underneeth the fuse box in the right side of the hood. Fuse # 23 , it's a light blue 15 amp.
3: Cut the wire in half ( it's a dark blue wire with a light blue stripe.)
4: Solder the red wire of the adaptor to the wire (that you just cut) that goes to the fuse box.
5: Solder the red wire with a green stripe from the adaptor to the wire (that you just cut) that goes to the engine.
6: ground the black wire to the battery
7: solder the grey wire from the adaptor to the green wire that comes from your tachometer. ( don't forget to set your tachometer to 4-6 or 8 cylinder )
that's it..
Pardon mi righting, caus i'm a french canadian dude.
Old Jul 26, 2011 | 07:31 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum I don't know if he ever figured it out, since the thread is 3yrs old, but thanks for the info. I'm sure someone will benefit from it.
