Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
ODBII Code P000A
Old Jan 30, 2008 | 12:03 PM
mlgraves2's Avatar
mlgraves2
Default ODBII Code P000A
Does anyone know what the P000A code is on the 2007 Caliber automatic. I think my wife did not tighten the gas cap tight enough, and after talking to the dealer if it is the loose gas cap then they want $89 to turn off the engine light. Heck Ican go buy my own ODBII reader and turn off the light my self for that price.
Old Jan 30, 2008 | 12:18 PM
bigtsr's Avatar
bigtsr
Default RE: ODBII Code P000A
P000A is a code for camshaft slow response on the Caliber.
Go here for all the codes:
http://www.caliberforumz.com/showthread.php?t=1796
Old Jan 30, 2008 | 12:30 PM
mlgraves2's Avatar
mlgraves2
Thanks for the info, guess I will be taking into the deaer.
Old Jan 30, 2008 | 01:01 PM
Jib01's Avatar
Jib01
I would assume that if you put the gas cap back on tight that the computer should reset itself. You should not have to pay for that. It should be built into the computer.
Regards
Jib01
Look here
NUMBER: 14-001-06
GROUP: 14 -Fuel System
DATE: January 21, 2006
SUBJECT:
Loose Fuel Cap Message or MIL Illumination for Diagnostic Trouble Code P0457 -EVAP
System -Loose Fuel Cap
MODELS:
2005 -2006 (ND) Dakota
2005 -2006 (CS) Pacifica
2006 (DR/DH) Ram Truck
2005 -2006 (HB) Durango
2005 -2006 (KJ) Liberty
2006 (LX) 300/Magnum/Charger
2006 (PT) PT Cruiser
2007 (PM) Caliber
2006 (RS) Town & Country/Caravan/Voyager
2006 (TJ) Wrangler
2005 -2006 (WK) Grand Cherokee
2006 (XK) Commander
NOTE: This bulletin applies to all vehicles equipped with a gasoline engine.
NOTE: Do not replace the gas cap if only DTC P0457 -Evap System -Loose Fuel
Cap is present.
DISCUSSION:
Starting with the introduction of 2005 model year vehicles a new diagnostic trouble code
(DTC) P0457 -Evap System -Loose Fuel Cap was introduced. Also added to some
vehicles was an instrument cluster message in the odometer display or message center
(EVIC) that alerts the driver that the gas cap is loose.
The PCM monitors the fuel level for a "significant" change in either direction and
remembers that this has recently occurred. A loose fuel cap DTC, cluster message or
message center message matures when the check for the EVAP system large leak
condition fails after the fuel level change event. If a leak of greater than 0.090" is observed
after a fuel level change, a loose cap diagnostic single trip failure is stored and the cluster
14-001-06 -2-
message or message center message is displayed even though a DTC may not yet be
present. DTC P0457 -Evap System -Loose Fuel Cap is stored and the MIL illuminated
after 2 cold start failures of the large leak diagnostic checks following a fuel change event.
Only the passing of one of the 3 EVAP system diagnostic routines large leak, small leak or
loose gas cap) by the PCM will validate that the cap is no longer loose and turn off the MIL
light or message.
For 2007 model vehicles DTC P0457 -Evap System -Loose Fuel Cap will be stored and
the MIL illuminated after 3 cold starts.
To temporarily clear the gas cap loose message from the odometer or message
center press the reset button on the odometer or message center while the message is
being displayed. This clears the message for the current key cycle only.
NOTE: The above works for all vehicles except, 2005 -2006 Grand Cherokee or
Commander. For these, the scantool must be used)
To clear the gas cap loose message from the odometer or message center ensure
the gas cap is tight and let the vehicle run the small leak diagnostic routine. The small leak
diagnostic routine will pass a sealed system after an 8 hour soak and a negative 3° C
change in fuel temperature from the last key cycle.
NOTE: A heated garage may effect the small leak diagnostic routine.
To clear the gas cap loose message from the odometer or message center and
matured DTC (MIL light) diagnose and repair the leak and then erase DTC's with the
DRB III®/StarSCAN™ scantool
NOTE: The DRB III®/StarSCAN™ scantool may be used to reset the Loose Cap
message. Select the PCM Reset function on StarSCANâ„¢ (version 6.05_SP1
or higher) or the Clear PCM Batt Disconnect function on DRB III®.
Disconnecting and reconnecting the battery will also clear the message.
If a gas cap loose message is displayed or DTC P0457 -Evap System -Loose Fuel Cap is
set without P0455 -Evap System Large Leak then ensure the gas cap it tight, no further
service action is required.
POLICY:
Information Only.[/align]
Old Jan 30, 2008 | 02:40 PM
mlgraves2's Avatar
mlgraves2
Got a response from the dealer. There is a firmware update for this error, and according to the dealer there is a special oil that should be used in the Caliber. Anyone know anything about it?
Old Jan 30, 2008 | 08:32 PM
bigtsr's Avatar
bigtsr
The owners manual tells you 5W30 for the standard Caliber engine
options,as for special oil I think your dealer is setting you up
for additional charges that aren't called for at all.
Possibly if you can find another dealer within reasonable driving
distance and check out their story.
I have driven my Caliber 1-1/2 years and the car has only been
back to dealer for my free oil changes plus 1 software update which I requested.
Many of the Caliber owners have switched to full synthetic oil such as
Mobile 1 or Royal Purple at the first service check and have been happy
with the resulting better mpg and longer service interval.
