Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Gas fill overflow
Old Sep 15, 2008 | 08:44 PM
04StratusR/T's Avatar
04StratusR/T
Hmmm...thats weird! I've never experienced this issue with either of my Calibers. I do however take out the nozzle very slowly and let it drip a few seconds. I pisses me off when gas drips on my rear fender!
Old Dec 28, 2008 | 06:46 PM
Junkman1's Avatar
Junkman1
Do you drive in dirty dusty conditions like gravel roads? I drive on gravel roads alot and my Caliber SXT started doing the gas burp thing at about 40,000 miles. I blew air from my compressor through the Evap filter located by the gas tank behind the rear left wheel and all ok.
Old May 19, 2009 | 06:33 PM
CTCaliberSE's Avatar
CTCaliberSE
I bought my 07 Caliber a little over a month ago. I have been having the same problem when I fill the tank. If I let the pump shut off, and then remove the nozzle gas always spills down the side of the car and on the ground. It's not a trickle, it's a gush. I'm not topping off the tank, so I didn't think I should have a problem. I wonder if the pump is shutting off too late, but it has happened at different pumps. The only common denominator is the vapor recovery nozzles the all the pumps here in CT have.
Old May 19, 2009 | 08:53 PM
lxman1's Avatar
lxman1
Site Moderator
May be a venting issue as mentioned above.
Old May 20, 2009 | 06:29 PM
Junkman1's Avatar
Junkman1
You need to clean the evap filter. See post on 12/28/08. I did this at 40,000 miles and now have 61,000 and no trouble the last 20,000. The filter is in a bad spot should have been located under the hood like most older vehicles.
