Cooling fans not running
Nope, I have tried everything that you suggested and still no luck. I'm stuck and I hate to bring it to the dealer but I don't know what else to do!
Kindest regards,
Tom
If it had an accessible relay, it will be under the hood in the power distribution box where the fuses are. It should tell which relay it is on the bottom of the cover. The relay will have the pins numbers on the top usually.
I have an 07 dodge caliber and my double fans not coming on and the ac not blowing cold checked the fuse was good hooked up my fans direct and both work hooked the compressor direct and blew cold air and it's not over heating either anybody that can tell me what to check next
Welcome to the forum.
Do your fans come on when the temp gauge gets about 1/2 way up? This is about where they come on without the a/c on. If so, then your a/c circuit. Does the snowflake switch light up when you turn on the a/c?
