Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Headlight Issue
Old Dec 20, 2010 | 04:42 PM
DodgeX4's Avatar
DodgeX4
Default Headlight Issue
My son's Caliber has a head light out. He replaced the fuse and the bulb with no effect. If anyone knows the best way to trouble shoot from this point on I would appreciate any help.
thank you,
jim
Old Dec 21, 2010 | 11:39 AM
DodgeX4's Avatar
DodgeX4
Default added info
My son told me last night that the high beam works, but not the low beam, and that's only on one of the headlights.
Again, I appreciate any help you may be able to provide.
thanks,
jim
Old Dec 21, 2010 | 11:44 AM
dakota_raven's Avatar
dakota_raven
Try reseting the computer by disconnecting the battery . Maybe the computer still sensing that the bulb is still burned and does not recognizes the new one!! Try that!!! Good Luck!!!
Old Dec 21, 2010 | 03:55 PM
lxman1's Avatar
lxman1
Site Moderator
Yes, The computer seems to control everything on these cars, even the radio. If that doesn't work, it could be either the light socket is bad (check for voltage with a test light or meter) or possibly the multi-function switch in the column. You might also take the working bulb and move it to the other side just to verify that the new one is not bad as well.
Oh, by the way, welcome to the forum!!
Old Dec 23, 2010 | 11:10 PM
steak59's Avatar
steak59
on the Caliber, sometimes you have to reset the Tipm module(Fuse block) b4 the head light starts working again. Try disconnect the battery, or Pull the IDO fuse for a minute.
Old Dec 24, 2010 | 12:55 AM
lxman1's Avatar
lxman1
Site Moderator
Welcome aboard Steak.
Old Dec 24, 2010 | 07:45 PM
steak59's Avatar
steak59
Thanks, think i should go make a thread on New Member Area.
