Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Rad Fans
Old Jun 6, 2011 | 11:11 AM
zoniman's Avatar
zoniman
Default Rad Fans
Car over heated, guage shows normal temp. (two lines under half way mark). over temp light came on. The Rad cooling fans not operating. Fuse 15 (40 amp) is good. I have no idea at this point were the Fan relay is. It may not even be the relay since the temp gauge is getting wrong Signal. Any ideas?
Old Jun 6, 2011 | 09:26 PM
steak59's Avatar
steak59
does the fan work when u turn on the A/C?
maybe not the relay, because there are like 3 or 4 relays for different speed. and all relays are in the fuse box.
Old Jun 7, 2011 | 10:25 AM
zoniman's Avatar
zoniman
Default fixed :)
After i found manual on this site. I did some research and found that one of the coolant temp sensors send the signal to the gauge and fans. Replaced and now all good.
Old Jun 8, 2011 | 06:54 PM
lxman1's Avatar
lxman1
Site Moderator
Thanks for the update.
