i need advice on my caliber, PLEASE HELP!
It goes ON and Off? that means ur car is failing the evap monitor once in a while.
My guess would be a bad ESIM switch on on charcoal canister. very cheap and takes 15 mins to change, if u feel comfortable working under the car.
Tho, it could be a leaking hose or gas cap, further test will need to be performed.
If it is not fix, u will not pass emssion, and become a source of our air pollution and global warming!
other than that, ur car will run fine as usual. This is just a emission thing u can neglect for now.
however, if there is something else wrong with ur car, there is only 1 check engine light on the dash, and u will not notice.
