Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Clicking noise in front driver's side of 2011 Caliber
Old Sep 12, 2011 | 09:38 AM
spuyear's Avatar
spuyear
Default Clicking noise in front driver's side of 2011 Caliber
I recently purchased a 2011 Caliber Mainstreet. So far, I like the car but am annoyed by a clicking or ticking noise from what I think is under or in the driver's side dashboard. I get it when I start of and sometime when I am just sitting in traffic.
Any thoughts?
Old Sep 12, 2011 | 02:38 PM
DodgeCares's Avatar
DodgeCares
If you want to PM me your VIN I can check for any TSB's or recalls on this issue.
Old Sep 13, 2011 | 07:58 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum. It almost sounds like it could be a blend door actuator slipping, but those are usually more towards the passenger side.
Old Sep 14, 2011 | 10:09 PM
spuyear's Avatar
spuyear
Thank you. I did some research on the blend door actuator and am thinking that may not be the issue. I almost think something in the left side of the dash is a bit loose. Since the vehicle is so new, I think I just need to give it a little time to see if it discontinues. Thank you again!
Shawn
Old Sep 15, 2011 | 11:58 AM
DodgeCares's Avatar
DodgeCares
Shawn
Shawn,
If you cannot figure it out the dealership should be able to find and correct the problem for you. No need you should have to put up with that on a new vehicle.
