Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
engine light, no code, 5 beeps ?
Old Oct 26, 2011 | 04:23 PM
taylorde's Avatar
taylorde
Default engine light, no code, 5 beeps ?
The check engine light came on in our 2008 Dodge Caliber SXT, I flipped the ignition 3 times, it shows all dashes, there are 5 beeps, then the dOne appears. Any idea what is the problem? The tire pressure warning is also on, but that has been on for 2 weeks.
DaveT
Old Oct 26, 2011 | 05:59 PM
lxman1's Avatar
lxman1
Site Moderator
Might want to run by your local autozone to get it scanned. You also need to check your tires. If one gets down to 28psi, the light will come on. Common as the temps drop in the fall.
Old Oct 27, 2011 | 09:31 AM
DodgeCares's Avatar
DodgeCares
DaveT
Dave,
There are a couple of software updates for MIL illumination errors on the Calibers. If you PM me your VIN I will find if any apply to your vehicle.
