Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
back windshield wiper
Old Jan 13, 2012 | 12:16 AM
bailes's Avatar
bailes
Question back windshield wiper
2007 caliper...back window wiper quit working...is there a fuse somewhere? i looked in the box in the engine compartment didn't see one...could use some help...thanks
Old Jan 13, 2012 | 01:38 PM
lxman1's Avatar
lxman1
Site Moderator
If there isn't one under the hood, I doubt that it has one. It could be a bad motor or switch. I would remove the hatch panel and check for voltage to the motor while someone turns the switch on and off with either a meter or test light. If you get voltage, then it is probably the motor, if not, I would suspect the multi-function switch in the steering column.
You might try downloading the free service manual to help diagnose your problem.
https://dodgeforum.com/forum/dodge-c...ce-manual.html
