Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
A/C issues
Old Oct 20, 2012 | 11:46 AM
JBlanco's Avatar
JBlanco
Post A/C issues
hi first time on the forums i have a dodge caliber 2007 model car and my A/c started acting up by not working on any of the levels of a/c except for max and now it wont even work on max level if there anyone that could shed some light on this issue that would be most appreciated
Old Oct 21, 2012 | 12:46 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome.
Are you talking about the blower itself?
Old Oct 23, 2012 | 10:59 AM
DodgeCares's Avatar
DodgeCares
JBlanco,
Welcome to the forum. First thought is blower motor or switch from your description but need more info such as does it not blow at all, if it does blow is it warm air, no flow, etc...?
Old Oct 25, 2012 | 01:25 PM
JBlanco's Avatar
JBlanco
Originally Posted by lxman1
Welcome.
thank you and yes its the blower
Old Oct 25, 2012 | 01:26 PM
JBlanco's Avatar
JBlanco
Originally Posted by DodgeCares
JBlanco,
it does not blow at all the switch works its ether the blower or wiring and thank you for the welcome
Old Oct 25, 2012 | 02:31 PM
DodgeCares's Avatar
DodgeCares
My thought would be the blower motor itself.
Old Oct 26, 2012 | 08:20 PM
lxman1's Avatar
lxman1
Site Moderator
If it only works on high, then it is probably the resistor pack. Sounds like either that or the switch in the dash. If you have a test light or meter, you can check for 12 volts at the motor leads. If you do have 12v, then it should be the motor itself.
