Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
P1607 O/P circuit malfuction
Old Jun 4, 2013 | 05:17 AM
tim1's Avatar
tim1
Default P1607 O/P circuit malfuction
Hi Guys, newbie here from South Africa.
I have a 2007 Dodge Caliber. My MIL light came on, I had the car scanned, it came up with error code P1607. I checked on the forum here that it is a O/P circuit malfunction.
Please could someone tell me what O/P circuit malfunction is or means?
Sorry if this has been covered somewhere else in the forum, I couldn’t find anything.
Thanks!
Tim1
Old Jun 5, 2013 | 07:12 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum!!
Could be a bad battery, but here is the manual's check list that I found
P1607-PCM INTERNAL SHUTDOWN TIMER SLOW RATIONALITY
For a complete wiring diagram Refer to Section 8W.
When Monitored:
Continuously.
Set Condition:
The PCM has detected an interruption in the supplied battery voltage while the module is powered down. Two Trip Fault. Three good trips to turn off the MIL.
Possible Causes
INTERMITTENT DTC
PENDING TEMPERATURE SENSOR DTCS
LOW BATTERY VOLTAGE TO MODULE
(F202) FUSED IGNITION SWITCH OUTPUT (RUN-START) CIRCUIT OPEN OR HIGH RESISTANCE
(A931) FUSED B+ CIRCUIT OPEN OR HIGH RESISTANCE
POWERTRAIN CONTROL MODULE (PCM)
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - STANDARD PROCEDURE) .
Diagnostic Test
1. PENDING TEMPERATURE SENSOR DTCS
Turn the ignition on.
NOTE: If any temperature sensor DTCs are present, allow the vehicle to cool completely before proceeding with this test.
Start the engine and allow it to reach operating temperature.
With the scan tool, select View DTCs.
Are there any pending Engine Coolant Temperature sensor, Ambient Air Temperature sensor, or general temperature DTCs?
Yes
Diagnose and repair any temperature sensor DTCs and retest.
Perform the PCM Verification Test Ver. 1 (Refer to 9 - ENGINE - STANDARD PROCEDURE) .
No
Go to 2
2. DTC IS ACTIVE
With the scan tool, select View DTCs and review the DTC environmental information for this DTC.
Is the good trip counter greater than 0?
Yes
The DTC is not active at this time. Refer to the *CHECKING FOR AN INTERMITTENT DTC Diagnostic Procedure. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
No
Go to 3
3. LOW BATTERY VOLTAGE AT PCM
NOTE: A loss of battery voltage to the module while the module is powered down is the most likely cause of this DTC.
Inspect all PCM power and ground circuits.
Inspect and test the battery in accordance with the Service Information.
Inspect the generator drive belt for proper alignment and adjustment.
Inspect the vehicle for aftermarket accessories that may exceed the generator system output.
Inspect the fuses in the IPM. If an open fuse is found, use the wire diagram/schematics as a guide and inspect the wiring and connectors for a damaged or shorted circuit.
Were any problems found?
Yes
Repair as necessary.
No
Go to 4
4. (F202) FUSED IGNITION SWITCH OUTPUT (RUN-START) CIRCUIT OPEN OR HIGH RESISTANCE
Turn the ignition off.
Disconnect the PCM harness connector.
With a 12-volt test light connected to ground, check the (F202) Fused Ignition Switch Output (Run-Start) circuit.
Check the circuit with the ignition switch in the OFF, ON, and START positions.
NOTE: The test light should be illuminated and bright with the ignition switch in the ON and START positions. Compare the brightness to that of a direct connection to the battery.
Wiggle test the circuit while checking with the test light to check the circuit for an intermittent problem.
Does the test light illuminate, or not illuminate, as expected in each of the ignition switch positions?
Yes
Go to 5
No
Repair the circuit as necessary. If an open fuse is found, inspect the circuit for a short to ground.
5. (A931) FUSED B+ CIRCUIT OPEN OR HIGH RESISTANCE
With a 12-volt test light connected to ground, check the (A931) Fused B+ circuit.
NOTE: The test light should be illuminated and bright regardless of the position of the ignition switch. Compare the brightness to that of a direct connection to the battery.
Wiggle test the circuits while checking with the test light to check the circuit for an intermittent problem.
Is the test light illuminated and bright in each of the ignition switch positions?
Yes
Go to 6
No
6. POWERTRAIN CONTROL MODULE (PCM)
Using the wiring diagram/schematic as a guide, inspect Powertrain Control Module power and ground circuits.
Look for any chafed, pierced, pinched, or partially broken wires.
Look for broken, bent, pushed out or corroded terminals.
Monitor the scan tool data and wiggle test the wiring and connectors.
Look for the any data to change or for the DTC to reset during the wiggle test.
Refer to any Technical Service Bulletins that may apply.
Yes
No
Replace and program the Powertrain Control Module (PCM) in accordance with the Service Information.
Old Jun 6, 2013 | 06:17 AM
tim1's Avatar
tim1
Thank you for the reply!
Could well be the battery or related, I changed the battery, maybe they fitted an incorrect one or something like that.
The help is much appreciated!
Old Jun 12, 2013 | 07:32 PM
lxman1's Avatar
lxman1
Site Moderator
Let us know what you find out.
