2011 Caliber Master Switch Removal Help
Hello All,
Found this forums today and need some help. I have a 2011 dodge caliber and the driver front windows will not go up anymore using the switch. it will go down and all other windows go up and down. I can only get it to come up by angleing the switch in a weird way while holding it in the up position..
I want to replace the master switch but wanted to know if the best method. I cant seem to find a guide online. I am assuming I can pop off the center door part after removing the handle screw, then remove the switch assembly from there pretty easy. Am I missing something? thanks in advance!
You got it. There is one screw in the pull cup handle part under a plastic cap. Remove that screw and the center panel portion with the arm rest and switch assembly can be popped out. Use a screwdriver or other flat bladed tool to start it, then just pull it off to access the switch assembly.
