Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Radiator fan always on
Old Mar 11, 2017 | 10:04 AM
m@se's Avatar
m@se
Default Radiator fan always on
Hello guys, I have a caliber crd 2.0 diesel, I realized that to be a bit 'of time I have the radiator fan always on. To be cold or hot engine it is. The car off also turns off her. What do you think it might be, I know that there is a liquid sensor but I did not understand if there is also a relay and where it is located. What do you recommend, tomorrow will replace the liquid sensor, I could also check?
Old Mar 21, 2017 | 09:34 AM
lxman1's Avatar
lxman1
Site Moderator
it is more than likely located inside the PCM. I know they will run anytime the the a/c compressor is on, which is when the snowflake button is lit or if the control is set to floor/defrost or defrost and the blower is on.
