Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
07 dodge caliber sxt
Old Dec 9, 2017 | 09:40 AM
Richard Geiger's Avatar
Richard Geiger
Default 07 dodge caliber sxt
This very morning, it's cold. The blower motor isn't working, I hook up an external heater. After ten minutes the car is in limp mode without check engine light. What is causing this?
Old Dec 9, 2017 | 08:21 PM
Anything. Need more info.
Old Dec 10, 2017 | 09:42 AM
Richard Geiger
This is the second time now the lightning bolt symbol flashes when it is in limp mode. I've narrowed it down to the acceletator pedal sensor, throttle body, or worst case scenario the tipm.
Old Dec 10, 2017 | 10:21 AM
primem's Avatar
primem
there has got to be a fault code if the drive by wire throttle symbol is flashing. post the code.
Old Dec 10, 2017 | 11:53 AM
Richard Geiger
Don't have it atm, I will get it after I get off from work.
Old Dec 12, 2017 | 08:53 AM
Richard Geiger
Found the problem afte doing a code scan, it was the coolant temp sensor, replaced and cleared the codes. That 1 sensor was throwing the car into limp mode.
