08 Caliber abs/trans issue
Hey so I have an 08 Caliber and I’m having issues (surprise surprise). I had to change the front driver side turn signal and I did this by popping the plastic cover out of the wheel well to gain access. I changed the bulb and as soon as I started the car up the abs light came and stayed on and the transmission won’t change gears while driving as well as the temp gauge is going crazy. Is it possible I knocked something loose while changing the bulb? I wasn’t able to see too well while I was changing it and was doing a lot of feeling around. If there is anything that’s up in that area or runs through there that may have been bumped loose or disconnected that could be causing these issues please let me know, or if anyone else has come across this happening and how it was resolved. Thanks for the help!
