ECM replacement procedure?
Hi
Had a chronic po440 Large EVAP leak CEL, Dealer told me was bad ECM(PCM) . I got new ECM (PCM) and replaced it, now all the CEL lights I had on before are clear but now I have a Throttle Control light on and car runs like crap ( ran fine before) is there a procedure to reset the ECM or am I missing something here?
Thanks in Advance
2007 Caliber SXT
Thanks in Advance
2007 Caliber SXT
I can't help with why it doesn't run like it did before the new PCM. My high mileage 2007 had constant throttle body problems until I cleaned it, then put a "oil can catcher" in the pcv vacuum line (so the oil blow-by) would not dirty-up the throttle body....eventually I removed the intake manifold because it was dirty too (the "butter fly" air flow conditioners) at the top end of the intake manifold really get sticky too.
"oil can catcher" is actually called an oil separator. Highly recommended to keep the throttle body, intake manifold clean.
If you do remove the intake manifold to clean it...here is a tip: the screws that hold the butter fly's (air flow conditioners) don't tighten them too much, make sure the axle there is freely to move. tighten them down it won't work right.
