Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
07 Caliber Dies Unless Gas Is Pressed
Old Jan 23, 2022 | 03:00 PM
Smtomes's Avatar
Smtomes
Default 07 Caliber Dies Unless Gas Is Pressed
Hello,
I have a friend who is wanting me to repair their 07 Caliber, but I want to make sure I am fixing the right thing.
Her car will stall out unless you keep your foot on the gas pedal. When driving it you have to keep giving it a little gas even when stopped or else it will die.
Any advice on what may be going wrong would be appreciated.
Old Jan 23, 2022 | 04:47 PM
What engine? How many miles? Scanned for codes? Maintenance up to date? Need more info.
Old Jan 24, 2022 | 04:51 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by Smtomes
Hello,
I had a Dakota back in '94 that was not quite a year old do that. Twice it went to the dealer with the same issue. After warranty, I tore into it and all it needed was a cleaning on the throttle body. Try cleaning the throttle body and see what happens. Be sure to use throttle body cleaner and NOT carburetor cleaner. Gummout even said for years on the can to NOT use it on throttle bodies. Pull the intake system apart until you can get to the throttle body. Clean it with the cleaner and a paper towel. Don't use cloth. A piece of paper will burn off if it gets in. Cloth may not. Rub the paper around until it comes out clean. Reassemble everything and start it. It will run like crap for a bit and might be hard to start. It will eventually burn all the gooky stuff off and smooth out. This may clear the problem if it's just dirty.
