Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
caliber headlight mods
Old Dec 19, 2006 | 06:20 AM
caliberlover07's Avatar
caliberlover07
Default caliber headlight mods
Has anyone done any mods to their cali headlights by switching out the bulbs to different types of Halogens? I have read alot about these "cool blue", "Bright white" etc etc for the bulbs.
Has anyone purchased anySylvania Silverstarbulbs or thenew Silverstar Ultra bulbs?
I hear also that these bulbs dont last as long as a regular bulb.
Old Dec 19, 2006 | 10:29 AM
bigtsr's Avatar
bigtsr
Default RE: caliber headlight mods
I personally think the stock bulbs in the Caliber are very bright and more than
adeqate,however I have seen on other forums that owners are switching them
out for Sylvanias or GEs.
There has been a noted difference in service life of these bulbs however
and if you check on the other forums you see that if you do a lot of night
driving you will be replacing them more often,could be with the Caliber
using the high beam for Daytime Running Lights the longevity may also be
reduced.
Old Dec 19, 2006 | 02:21 PM
TUNDRA_schumacher's Avatar
TUNDRA_schumacher
I agree. I think the stock ones are plenty bright.
Old Dec 19, 2006 | 08:02 PM
dragon8master's Avatar
dragon8master
i agree that the stock lightbulbs are plenty bright. But, i've had the silverstars in my neons, and they made a BIG difference. I will get them for our Caliber when one of the stock one blows.
Old Dec 19, 2006 | 08:30 PM
DarkHorse's Avatar
DarkHorse
I do a lot of night driving here in the UK, and have fitted some Philips GT150's. They have a whiter light, and penetrate further than the stock bulbs. I believe the Silverstars are similar, but lack the blue highlight. I fit new bulbs on every car I own, they do make a difference at night. Not noticed any issues with lifespan either.
Hope this helps..
Old Dec 19, 2006 | 08:34 PM
RT 2 NV's Avatar
RT 2 NV
i order a lot of bulbs off ebay and from my local stores. and i have had great luck with the cool blue or hyper blue lights my self. nice thing about buying from the store you can return them if youdont like them. just say you didnt install them.every stock bulb can be upgraded. every car i have ever had i do the upgrade an it is alwyas much brighter wider, longer, and blue white looks much better then stock yellow. i am a big fan of the hyper blue color. i havehyper blues inmy charger know.just my 2 cents. good luck.
Old Dec 20, 2006 | 05:01 AM
Hog54's Avatar
Hog54
I think the lights are bright enough.In fact none of my friends will ride in front of me at night cause it says it blinds them through rearview mirror.
Old Dec 21, 2006 | 03:15 AM
caliberlover07
I have the same thing about blinding my friends at night with my regular lights. They also don't like driving too close behind because of the bright tail lights.
Old Aug 23, 2007 | 01:20 AM
talon98's Avatar
talon98
The biggest issue when you install aftermarket bulbs is that many of them are higher wattage bulbs. If you don't upgrade the stock harness by adding a relay to power them it will usually cause the bulb to burn out prematurely or will melt the socket right into the headlight. So if you are going to install the aftermarket bulbs make sure you are staying in the same wattage range, add the relay to power the lights from the battery, or plan on replacing the headlight socket a bunch.
Old Feb 14, 2008 | 05:28 PM
somenothingness's Avatar
somenothingness
I ran xenon bulbs with the blue tint but super white light in my 06 sentra 6 months ago. I put them in my caliber 3 weeks ago too. BIG difference. I have had no problems to date. Got them on Ebay for 10 bucks a pair. I ran silverstars in my 96 stratus. Couldnt tell a big difference.
