ECM ground
Old May 1, 2007 | 01:49 PM
zugzee's Avatar
zugzee
Default ECM ground
I would like to know how to check the ECM for ground, as I get a message from the code reader something like "unable to communicate with the vehicle." I replaced the ECM with a used one and still get the same message, so I'm wondering if the ground is good, but as the case is all plastic I do not know where the ground runs.
Thanks for any help anyone can offer.
Old May 2, 2007 | 02:21 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: ECM ground
I need to know what year your van is. You may need to disconnect all of the other controllers one at a time until you ecu comes back. most of the time its the tcm. The one that is unplug is your probem, also disconnect the cluster as the last resort.
Old May 2, 2007 | 01:05 PM
zugzee's Avatar
zugzee
What a dope I am.
The Dodge Caravan is a 1992--3.0 liter with 190,000 miles on her. Has run very well all these years and I would like her to set a mileage record.
I thank you for your help!
Troy Benson
