The dreaded "Clunk"
Old May 30, 2007 | 01:05 PM
madsabre's Avatar
madsabre
Default The dreaded "Clunk"
As many before have experienced, my '03 with 35K miles started the front-end clunking. I took it to the mechanic who told me the links needed replacing at $51 a pop. Hesitant to pay parts and labor for this, I found this forum to see what else could be wrong. It appears the sway bar bushingmay beshot in addition to the links. So, a few questions...
1. Is there any safety concern with the bushing/links being worn and making noise?
2. What about long term effects with respect to replacement costs?
3. Are the link bushings replaceable or are they pressed into the link requiring specialized tools to replace?
4. Can I replace the sway bar bushings / links without a Chiltons manual?
5. Should I replace the bushings and link all at once or just start with the bushings and go from there?
6. Does anyone have any pictures of this area?
7. Of those who have performed this replacement on their own, how long did it take?
Thanks in advance for the help,
Mike
Old May 30, 2007 | 10:23 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: The dreaded "Clunk"
right now nothing but a noise untill teh links fall apart all together.
louder noise
links are one assembly the rubber is built in
u haft to take down the sway bar down just do both at the same time
dont need pics get the parts and u can see them not hidden
takes me 20 min but i have done them a few times and plus i lift the car up u will more then likely be doing this on the ground
