stals in gear
Old Jun 14, 2007 | 02:07 PM
Lrossxxl's Avatar
Lrossxxl
Default stals in gear
I have a 96 caravan and last night it died on me.. it will start and run in park and neutral but as soon as i put it into gear it bogs down and shuts off... no ck engine light comes on and all the fluids look good. any suggestions would be great..
Old Jun 14, 2007 | 03:45 PM
next2pool's Avatar
next2pool
Default RE: stals in gear
There are a couple of possibilites. One is that the idle air motor is not bumping up the engine speed--that may be due to it not working or carbon build up blocking the port on the intake plenum. The other possibility is a locked up torque convertor clutch which is a much nastier issue. If you are in neutral and turn on the A/C system, does the idle speed go down, up, or stay about where it was? That may give an indication if the idle air system is working.
Old Jun 14, 2007 | 04:59 PM
Lrossxxl's Avatar
Lrossxxl
the ac dosent work. before we bought it they un-pluged the ac unit and as far as the carbon build it that woudl be a dream.... ive read other reports were people had the same problem and it wound up being the torq converter.. fun fun fun... im gonna play with it a little tonight and see what happens worse comes to worse ill junk the pos and buy her a new car
Old Jun 14, 2007 | 10:01 PM
next2pool's Avatar
next2pool
You might try upping the idle a bit with the throttle pedal (not too much) and put it in gear--if it still stalls, I'd guess the convertor clutch.
Old Jun 15, 2007 | 02:08 AM
master tech's Avatar
master tech
Site Moderator & Tech
Your torque converter is locking up causing the engine to stall out.
