how to tell if trany is in limp
Old Jun 21, 2007 | 12:39 AM
next2pool's Avatar
next2pool
Default RE: how to tell if trany is in limp
I'm not so sure you have a problem. If you can drive at highway speeds and the engine isn't screaming, it is probably on high gear. What I would do is drive at about 65 mph on level ground and then move the shift lever down one notch--if it makes no difference, then it probably isn't in top gear, but if you feel a downshift and hear an RPM increase, then it probably is doing just fine.
Old Jun 21, 2007 | 03:18 AM
ekoms's Avatar
ekoms
tried moving the leaver, makes no difference. the engine isn't screaming too bad, guess that's cause of the 3 speed ratios. but like I said I cant feel any shift shock at all and accelerating is ridicules slow, same as second gear in my Toyota and Nissan. does any1 know what speeds second/third gears would enable.
Old Jun 21, 2007 | 02:13 PM
next2pool's Avatar
next2pool
I'm wondering if it may be starting in 2cnd or 3rd--that may account for the slow acceleration. Under light to moderate throttle, I would expect a shift into second at about 15 to 20 mph and into third at about 40. Normally that is very throttle dependent. At wide open throttle, it would be about 45 and 75.
Old Jun 22, 2007 | 11:24 AM
ekoms's Avatar
ekoms
pickup new input/output sensors. will let you guys know what happens
Old Jun 23, 2007 | 06:15 PM
ekoms's Avatar
ekoms
New input/output sensors did nota, still won't shift. what else should I check ?
Old Jun 24, 2007 | 03:31 PM
next2pool's Avatar
next2pool
Sounds like you have something stuck in the hydraulic circuit--possibly in the valve body or the solenoid pack. I'm over my head at that point, but rather than spending money on more parts, it may be worthwulie to find a trans shop and have them do some line pressure checks-those should help diagnose a problem and shouldn't cost an arm and a leg.
Old Jun 25, 2007 | 11:46 AM
ekoms's Avatar
ekoms
thanks for the reply. Headed to the dealer today to get tcm read.
