97 Caravan, Shift (Gear) Indicator Problem
Old Jul 9, 2007 | 10:13 PM
mcetmc's Avatar
mcetmc
Default 97 Caravan, Shift (Gear) Indicator Problem
I am going to buy a 97 Caravan. When I move the shift lever to neutral, the dash display does not show an "N" or an "N" with a box around it.
Also, sometimes all the shift positions (P, R, N, D, 3, L) light and all have boxes around them.
Is the above caused by a mis-adjusted or bad switch connected to the shift lever?
Does all the positions lighting suggest a problem with the dashboard PC board or circuitry?
How do I get to it to adjust it or replace it?
I assume that the above will not affect the transmission or any other part of the van. True?
Old Jul 10, 2007 | 12:21 AM
shooter1's Avatar
shooter1
Default RE: 97 Caravan, Shift (Gear) Indicator Problem
i would suggest you have the vendor have this problem fixed before you buy the vehicle, unless you take the vehicle to a shop for a quote and have them reduce the price by that much.
i just replaced the shifter cable on my 99 3.8L and it was quite easy, and there's not much to adjust on it either, an 8 mm screw is all that's there.
however, i was doing some reading and there's a 'neutral switch ' or some such thing that can cause some problems so like i said i'd have it checked out before or instead of asking on this board and trusting the diagnosis from a stranger from afar.
Wayne in Calgary
ps i'm not too impressed with the lack of response on this board so you may want to try other boards as well.
[/align]
Old Jul 12, 2007 | 09:23 PM
master tech's Avatar
master tech
Site Moderator & Tech
Replace the Ignition switch, This was a common problem with 1996 thru 1998 caravans.
Old Jul 14, 2007 | 09:49 AM
dishdude2k's Avatar
dishdude2k
I have a 99 caravan.. it does the same thing.. and mine works just fine like that..
trans dont slip or anything.. runs great..
