Evaporator Replacement Help How To
Old Apr 6, 2009 | 03:49 PM
mr_mahoney's Avatar
mr_mahoney
Default AC evaporator replace with pictures
Here are the pictures of replacing a AV evaporator on a 2000 DGC
https://dodgeforum.com/forum/dodge-c...-pictures.html
Many thanks to Dodge Tech - I could not have done it without you.
Old Jun 28, 2009 | 05:27 PM
Wade's Avatar
Wade
Thanks Mahoney, I used your pics w/ the directions for my 1997 GC. They were very helpful. Had a few hang ups finding the 3 nuts inside the eng comp. all done. Now I just need to evacuate the system before I recharge it. Barrowed a vacuum w/ gauges from my neighbor that does warranty work on fridges. gauges manifold says it's can read the R-134a. Do I evacuate from the same port that I recharge the system? A pic inside a book from the part store shows where to recharge, but recommends the evacuating to a shop. Noticing (3) ports. (1) for the low end, (2) for the high end, and (3) that has a tag saying 'Evap. Service Port. max. 1 psi'
Old Jun 29, 2009 | 10:33 AM
mr_mahoney's Avatar
mr_mahoney
Default Evaporator Replacement Help How To
Glad to help. I took my van to local shop to have it "gassed" up. (only cost $50 - worth it for me to have it done right).
Old Jul 31, 2010 | 03:10 PM
rramkumar's Avatar
rramkumar
I have a 2002 dodge grand caravan, does any one know if the procedure to replace the evaporator is similar to the 2000. I have a leak in my evaporator and need to have it changed out.
Thanks in advanced.
Robert
Old Aug 23, 2010 | 09:39 PM
peektwice's Avatar
peektwice
Default 2001 Dodge Caravan
I just did this same repair on a 2001 Dodge Caravan. It's really similar, although I wish I had looked at the pictures of how to take the dash out as a unit. It's not hard, it's just time consuming.
Old Aug 23, 2010 | 11:01 PM
master tech's Avatar
master tech
Site Moderator & Tech
I like to welcome all the new members to dodge forum.
Old Oct 25, 2010 | 10:18 PM
ketram's Avatar
ketram
Unhappy new evap now it wont shift
I replaced the heater coil and the evap coil now the darn thing will not shift.
Being down to one truck sucks help.
Old Oct 25, 2010 | 11:32 PM
master tech
The transmission will not shift? What year is your van and engine size.
Old Oct 26, 2010 | 11:38 AM
mr_mahoney's Avatar
mr_mahoney
If you dropped your steering column, be sure to re-check your linkages and connections. also check the electrical connections. something might still be loose or not plugged in all the way.
