I want Daytime Running Lights
Old Aug 27, 2007 | 10:02 PM
3kids2minivans's Avatar
3kids2minivans
Default I want Daytime Running Lights
How do I engage the Daytime Running lights on my 2006 Town & Country? It's the base model. I would figure that it's some sore of relay that needs to be installed, but does anyone know for sure?
Old Aug 27, 2007 | 11:33 PM
brandoncrone's Avatar
brandoncrone
Default RE: I want Daytime Running Lights
Need to go to the dealer and have them access the customer preferences menu and activate the DRLs. No parts needed just a software change.
Old Aug 28, 2007 | 12:29 AM
haidangwa's Avatar
haidangwa
I have an '03 GC. The headlights automatically get turned off a few seconds after I shutoff and leave the vehicle. So, I just leave my headlight switch to the "ON" position permanently -- my cheap (free) solution for daytime running lights. I don't thinkthe GC's have a separate bulb dedicate to DRL, so my solution is just as good. In comparison, our Chevy Tahoe has dedicated DRL bulbs and light housing. The Tahoe uses a lower wattage bulb for DRL and automatically switches to full headlights on when it starts getting dark.
Old Aug 28, 2007 | 11:58 AM
next2pool's Avatar
next2pool
Most factory DRL systems power the lights at a lower voltage level than when they are in full on mode. They do that for bulb life and fuel economy. (not that you'd actually be able to measure the difference)
Old Sep 2, 2007 | 11:15 AM
Dodge Tech's Avatar
Dodge Tech
the day time running light is nothing more then a lower pulse with modulation voltage from the IPM to the lights them self software controled.
Old Sep 7, 2007 | 12:10 AM
DQC34's Avatar
DQC34
I'd like to get Daytime running lights on my 2001 Dakota Quad Cab would it be just a software issue? or would I need to get a part for it?
Old Sep 14, 2007 | 05:12 PM
DQC34's Avatar
DQC34
Just got my DRL working on my U.S. 2001 Dodge Dakota. Just went to the Dodge dealership and they changed the software in the ECU from U.S. to Canadian nothing else needed.Charged me with tax 61.00 CDN.
Where as my 1998 Dodge Dakota needed a DRL module which is under the hood on the drivers side that bolts on the fender,which I got at the junk yard for 5.00. There was an empty connector that led off the wires for the headlights/marker lights for the module to plug into.
