HELP! Can you DEACTIVATE sliding door alert system on 07 Caravan?
Old Sep 2, 2007 | 06:27 PM
kjohnsonusa's Avatar
kjohnsonusa
Default HELP! Can you DEACTIVATE sliding door alert system on 07 Caravan?
Have new 2007 Caravan with dual power sliding doors. I can't stand that clicking/flashing that going on when you open them up. I use my van for business and and constantly am opening the doors. I'm so sick of hearing that sound and there has to be a way to deactivate it, but how? Can someone please help me figure this one out? I would greatly appreciate it!
Old Oct 23, 2007 | 03:05 PM
ScottFenstermacher's Avatar
ScottFenstermacher
Default RE: HELP! Can you DEACTIVATE sliding door alert system on 07 Caravan?
Going from memory here:
Engine off. Cycle the ignition key between ON and RUN 4 times(don't start the engine). Then press the hazard light button, you should hear a chime (the hazards will also be blinking, go ahead and turn them off).
That should de-activate the warning.
Old Oct 23, 2007 | 11:24 PM
master tech's Avatar
master tech
Site Moderator & Tech
Its in the owner manual or a scanner.
Old Nov 26, 2025 | 03:25 PM
Catfish Phil's Avatar
Catfish Phil
Thank you!!!!!!!!!!!!! And it is not in the owner's manual! Could not find it anywhere.
