96 DGC 3.3 Transmission Problem
Old Sep 17, 2007 | 08:54 AM
dlm4ut's Avatar
dlm4ut
Default 96 DGC 3.3 Transmission Problem
I have 96 DGC with 3.3 engine and transmission with 140k. The engine starts up fine. However, the transmission does not work in any gear. The check engine light is not on and I plugged in my code reader and did not get any problem codes.
The car is in fine shape and was going to be donated to charity. They will give it to me for free. I am open to trying to rebuild the transmission, however, I am wondering if it is electrical or mechanical. Given that there are no problem codes I was guessing mechanical, but was wondering even with mechanical problems, electrical codes might still occur.
There was enough fluid and the gear selector cable was connected allright to the transmission.
Any ideas before I dive into rebuilding it.
dlm4ut
Old Sep 18, 2007 | 10:02 AM
dlm4ut's Avatar
dlm4ut
Default RE: 96 DGC 3.3 Transmission Problem
I did note another post that seemed to have similar problem and it was the converter, so I am guessing it is something like that.
However, I have a question that you all might know. If the TCM is bad or without power, will the transmission go into Limp mode and still work or will the transmission not work at all?
Also, I would guess there would be some codes if the TCM was not working, is that right?
dlm4ut
Old Sep 18, 2007 | 10:57 PM
master tech's Avatar
master tech
Site Moderator & Tech
If the transmission won't move, then there something wrong in the transmission. the tcm will stop the trans from moving the van. It on the other hand could stop the engine from starting and run, thats becase it will take the bus down.
