where is drl module 97 caravan
Old Oct 5, 2007 | 07:05 PM
airbud's Avatar
airbud
Default where is drl module 97 caravan
need to change i think ..i have no headlights or parks or interior lights ..it started with my wipers lol they didnt work and a freid of my said he could run two wires from fuse panel under hood to a toggle switch well he touched wrong spot and sapped my lights ..i got my wipers fixed changed my body module and fixed it ..i changed switch on colum and headlight switch and all relays and fuses have been check ..so what now wires,fuse panel under hood or drl module what do u think.....thanks
Old Oct 5, 2007 | 07:06 PM
airbud's Avatar
airbud
Default RE: where is drl module 97 caravan
anyone no
Old Oct 6, 2007 | 08:49 PM
greaseangel's Avatar
greaseangel
I have one, just have no clue what a drl module is lol. Guess that's about the only thing I've never had to fix You sure he didn't just blow all the bulbs with that zap?
Old Oct 6, 2007 | 09:24 PM
airbud's Avatar
airbud
drl is daytime running lights ..module
Old Oct 6, 2007 | 09:26 PM
airbud's Avatar
airbud
no not the bulbs put a wire from battery to wire that goes to headlight switch and parks lights and interior lights worked
Old Oct 7, 2007 | 08:21 AM
greaseangel
Oh, ok, that should be in the junction box, just above the relays.
Old Jun 17, 2010 | 07:25 PM
JustinK's Avatar
JustinK
The DRL Module is located under beside the steering wheel...almost directly infront of the driver knee...
