Popping drivers side wheel
Old Jun 17, 2010 | 10:39 AM
bullheadpond's Avatar
bullheadpond
Default Popping drivers side wheel
My 2008 caravan recenlty had a wheel bearing replaced and ever since we got it back it feels like something is loose or clunky. You can feel it in the steering and brake pedal when you hit bumps . It drives straight and is fine on smooth streets or highway. When my brother inlaw and i looked under neath i turned the wheel to the left and moved the steering wheel back and forth like 3-5 inches and he had his hand on the tire and could feel something popping i as he had his had on the tire.
Any idea what this could be?
I noticed that there are shiny new pcs on this side of the vehicle. one is a bracket and new looking small black hose that looks like it goes to the break and the other is a bar about 12-15 inches long that runs up and down . Kind of looks like it hooks onto the strut?
No one charged me for any new parts so i don't what they could have to do with the a wheel bearing. I thought the wheel bearing is inside the axle that your rotors sit on.
Old Jun 17, 2010 | 11:13 AM
Tizzy1's Avatar
Tizzy1
Tough call there, what couldn't they have left loose. Are you sure the lug nuts are tight? The long bar is the sway bar link, they make clunking noises over bumps. and yes, the hub and bearing go behind the rotor.
Old Jun 17, 2010 | 08:44 PM
mfahey's Avatar
mfahey
I would take it back and have them double check the torque on the nut that holds the wheel bearing in place.
