'o3 Caravan Cold!
Old Oct 29, 2007 | 08:20 PM
wmm's Avatar
wmm
Default 'o3 Caravan Cold!
I have an '03 Caravan that is only blowing cold air when the heat is on the fan is blowing hard but only cold air.
Help - Chilly n Philly
Old Oct 29, 2007 | 08:44 PM
richardh05k's Avatar
richardh05k
Default RE: 'o3 Caravan Cold!
Look for a vacum leak under the dash or eng comp.
Check the thermostat. make sure the top radiator hose is 190 deg. if the stat sticks all the way open you'll have a cold engine.
could be a plugged heater coil as well, that's a realy bad job.
Old Oct 30, 2007 | 01:58 AM
Dodge Tech's Avatar
Dodge Tech
hehe there is no vac system on an RS van u have low coolant more then likely leaking from your water pump.
Old Oct 30, 2007 | 09:45 AM
vlmuke's Avatar
vlmuke
anytime you don't have heat the first thing to check is the coolant level then go from there
