Changing Brake Pads
Old Nov 9, 2007 | 12:03 AM
mtngoatbb's Avatar
mtngoatbb
Default RE: Changing Brake Pads
open the bleeder? for real? why? so you dont contaminate the abs pump? tell me how there is contamination in a sealed system unless there was a leak? or someone put the wrong stuff in oh man... i am a certified chrysler mechanic and this is the kind of stuff that drives me nuts. open the bleeder....
Old Nov 9, 2007 | 11:51 AM
alwaysdutch's Avatar
alwaysdutch
My understanding is that you don't have to bleed the brakes when you have ABS and want to change the pads. In a case you need to replace a caliper, then only bleed that wheel. When you do not have ABS, you need to bleed all wheels.
Just my 2 cents. Always done it like that, never had problems.....
