fuses
Old Jan 17, 2008 | 10:20 PM
morris1's Avatar
morris1
Default fuses
2001 Caravan SE---turn signals, dash gauges, odometer---all don't work. Do not see any marked fuses for same under the hood fuse box over the drivers side wheel well. Any ideas?
Old Jan 18, 2008 | 01:05 PM
nvrplay2ty's Avatar
nvrplay2ty
Default RE: fuses
Ithink there is another fuse center under the dash, drivers side
Old Jan 18, 2008 | 08:25 PM
racin90's Avatar
racin90
Default RE: fuses
Yes. Possibly another fuse center just as you open the left door on the corner of the dash. Or disconnect the battery for 5 minutes and see if it all starts working. BCM could be having a problem and needs reset. Good luck
