lights on dash flashing..
Old Jan 22, 2008 | 04:52 PM
huston's Avatar
huston
Default lights on dash flashing..
I am trying to figure out how to get the lights on the dash (a/c, defrost...etc..4 or 5 lights) to stop flashing.
I took it to a garage and they said there is some squence you have to push the buttons in, in order to make them stop. And that a dealer would have that sequence....
Does anybody out there know what to do?
The lights on the buttons are about the size of a point of an ink pen.
Thank you,
Huston
Old Jan 22, 2008 | 05:38 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: lights on dash flashing..
COOLDOWN TEST ENTRY TO INITIATE TEST: [ul][*]Set Blower motor ON HIGH[*]Open all A/C outlets[*]Depress A/C and WASH buttons simultaneously for 5 Seconds (Until all LED's light) [/ul] RESULTS: [ul][*]All LED's will turn on for 5 Seconds.[*]Cooldown test is running if A/C and RECIRC are alternately flashing.[*]Acceptable result is when LED flashing stops.[*]Calibration Diagnostics and Cooldown must be run separately. [/ul]
