ABS brakes
Old Jan 22, 2008 | 08:52 PM
Bmcdonald54's Avatar
Bmcdonald54
Default ABS brakes
I have a 2001 Dodge Grand Caravan with out traction control. The brake and ABS light is on. The code states "valuve power failure" could somebody help me out. The fluid is good and the wheel will lock when on ice.
Thanks Butch
Old Jan 23, 2008 | 10:56 PM
vlmuke's Avatar
vlmuke
Default RE: ABS brakes
I am sorry I can ' toffer any assistance but I ma having the exact same problem hopefully someone will pipe up and offer a solution
Old Jan 23, 2008 | 11:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
Valve power feed failure.
Blown fuse #21 in the IPM same a PDC.
No B+ supply to fuse
Fused B+ circuit open
B+ circuit shorted to ground
CAB Fused B+ circuit open
CAB Fused B+ circuit shorted to ground
If you need the diag sheet,just send a pm. You will need a DRB3 to use the diag sheet because the sheets are from mopar. Leonard
