Help -- Cracked Rubber Hose on 99 Caravan
Old Feb 13, 2008 | 07:36 PM
mikechoy's Avatar
mikechoy
Default Help -- Cracked Rubber Hose on 99 Caravan
Hi All,
I found the small rubber hose between Airinlet resonator and top of the Engine is cracked. and there isa littleengineoil leakage the place of the crack. Does anybody know what does this hosefor and is it OK someleakaged oil?
Thanks,
Old Feb 15, 2008 | 03:43 AM
dishdude2k's Avatar
dishdude2k
Default RE: Help -- Cracked Rubber Hose on 99 Caravan
post pics.. hard to tell w/o seeing it.. also be helpful to know what engine .. etc.. it has
Old Feb 18, 2008 | 11:01 AM
next2pool's Avatar
next2pool
You may be talking about the intake part of the PCV system. If it is about 1/2 or bigger and has a right angle, that is what it is. It won't cause major problems but should be replaced so the PCV system will only suck in filtered air. They crack easily and you can get an exact replacement of get some regular fuel line hose at a discount supplier and slip it on--make sure it doesn't kink.
