Airbag light lit, what to check before costly dealer service?
Old Mar 17, 2008 | 11:46 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Airbag light lit, what to check before costly dealer service?
For the connectors you have clean, there isa recall G09 to replace the crash sensors. This recall is only on the 2005 mini vans. If you like the recall bulletin just send a pm or email.
Old May 1, 2008 | 09:35 PM
jag2003's Avatar
jag2003
Hi I have Dodge Caravan 2005 SXT I have the same Airbag light problem please send me info.
Old May 1, 2008 | 10:30 PM
D0TC0M's Avatar
D0TC0M
Just go to the dealer with your VIN number and they will tell you if your van is affected by this recall.
Old Jun 26, 2012 | 06:57 AM
rgarcia756's Avatar
rgarcia756
I have a 2005 Grand Caravan, 3.8L and had the problem with the ABS light continually on. I also noticed that the track control is off and was unable to switch them on. After connecting a scanner, it came up with a failure related to the EGR valve. I replaced the valve and the ABS fault dissappeared (this happened about year ago). Yesterday I took my van to be detailed and have the engine washed (ready for shippment back to US) and the ABS light came on again. I thought it could be water or moisture getting in the valve connector. I tried to dry the covalve connectors but the the fault is still present and the same problem of not being able to turn on the track control. Any suggestions???
Old Nov 1, 2013 | 09:42 AM
cnc5757's Avatar
cnc5757
my 2005 dadge carvan sxt airbag is on for the last year and half....need help
Old Nov 1, 2013 | 09:43 AM
cnc5757's Avatar
cnc5757
my dodage carvan 2005 airbag is on for the last year and half...need help fixing it
Old Apr 12, 2015 | 01:31 AM
melbourne's Avatar
melbourne
Just bought a2008 Grand caravan and the air bag light is on was there a recall on this ?
Old Apr 13, 2015 | 09:19 AM
DodgeCACares's Avatar
DodgeCACares
melbourne,
I'm sorry to hear about your airbag light concern. A diagnosis will determine what is responsible for its illumination.
You may enter you Vehicle Identification # at the website below in order to determine if there are any outstanding recalls on you van.
https://www.moparownerconnect.com/oc...allsQuery.aspx
Old Nov 17, 2017 | 12:04 PM
Mad Mel's Avatar
Mad Mel
Hey guys...just my two cents worth. Usually you will get a specific code for clock spring (not 100% sure you would on a Dodge) however if your horn honks and any other steering wheel controls work it most likely not the clock spring as any clock spring I have seen break its thin plastic ribbon with the conductors on it will break them all and nothing on the steering wheel will work.
Old Apr 5, 2018 | 08:58 PM
Pfar's Avatar
Pfar
Hi! My airbag light came on immediately after replacing faulty TIPM . I took the van to the dealer for diagnostics and they told me it was the clock spring and will cost $424 to replace however everything on steering wheel works - horn, cruise control. I asked the dealer if it could be related to the TIPM replacement and not actually the clock spring, they just said "no". But it seems too coincidental. Any thoughts?
