I need help with the infamous oil light switch
Old Mar 17, 2008 | 11:31 AM
caravan89's Avatar
caravan89
Default I need help with the infamous oil light switch
Hello Forum,
I have a 1989 Doge Caravan 2.5L non turbo mini van. It only have 138,000 mile. Lately I've been experiencing some problems with theoil light switch turning on. On many occasions the light will go on when the van is runing for a while. I've talk to some of my friends who are novice mechanic and some have told me that it could be that the engine is going bad. The " check inginge" light doesn't go on. I personally think that that the oil pump may be at fault. I will like to know why this only happens when the engine has been running for a while and not at the beginning when I turn on the engine. In addition, I notice that there is a small oil leak at the engine's head. Could this be the problem that is causing the oil light to go on? Any honest feedback will be greatly appreciated. Thanks!
Old Mar 17, 2008 | 01:54 PM
jubadah's Avatar
jubadah
Default RE: I need help with the infamous oil light switch
Does the light come on at speed or only at idle? My 1992 2.5 oil light would come on at idle only when the vehicle was warm (when the oil is thiner). I checked my oil pressure with a manual gauge and it was 18 lbs at idle. So I replaced the sending unit and the light stays off now.
Old Mar 17, 2008 | 06:08 PM
caravan89's Avatar
caravan89
The light comes on usually when Imake a stop on a red light. That would probably suggest that the engine is running on idle. Most of the time it happens when the engine has been running for a while.
Old Mar 17, 2008 | 11:01 PM
master tech's Avatar
master tech
Site Moderator & Tech
Ck the oil level and its full,and thentry a oil pressure switch 1st before tearing into a motor.
