Idling is all over the place
I have a 91 Caravan, 2.5L The idle is all over the place, but I wouldn't say it is a rough idle. It will accelerate to high rpm's on it's own and sometimes come back down to a normal idle. Other times, it will just idle high, then low, then really high and then back to normal. It never misses or runs rough, just idles high and low, but never low enough to kill the engine.
I'm not sure what this would definitely be, but I didn't want to start replacing sensors and have it not be the case.
I've checked for vacuum leaks, timing, spark plugs, plug wires, distributor, rotor, etc. Over 2 years ago I had replaced the IAC and the TPS sensors. I know for a while this thing was running very rich so I ended up changing the O2 sensors as well.
Does this sound more like the IAC? What do you all think?
Any suggestions would be fantastic!!
Thanks a bunch,
Pat Rogers
Thanks a bunch,
Pat Rogers
Thanks for your reply, I really appreciate it!
The AIS motor, is this different than the IAC? I'm assuming it is and haven't really looked under the hood or checked the manual for it. Could you tell me where the AIS motor is typically located?
Thanks again,
Pat Rogers
Thanks again,
Pat Rogers
