front brakes problem
Old Apr 3, 2008 | 08:01 PM
eddie718's Avatar
eddie718
Default front brakes problem
my front drivers side brakes keep locking up and the pads wear down very [&o]
quickly i changed the caliper the rotor and pads twice over the past year
and it is happening again as i drive the brakes lock up and heat up the
rotor to the point of them smoking any one have any ideas that can help
Old Apr 3, 2008 | 09:26 PM
OntarioRT's Avatar
OntarioRT
Default RE: front brakes problem
I would replace your flex brake line. The interior of the flex line has collapsed and is trapping the brake fluid, and not allowing the fluid to return to the master cylinder. This blockage will keep the brake pad bearing against the brake disc, causing excessive brake pad wear and overheating. Consider replacing both front flex lines at the same time, to prevent future brake problems.
Old Apr 4, 2008 | 08:25 AM
eddie718's Avatar
eddie718
thank you going to try and change hose today will respond as to outcome
Old Apr 4, 2008 | 03:00 PM
srs_49's Avatar
srs_49
How fast does this happen? After miles and miles of driving? Did it just start?
You might want to consider replacing the master brake cylinder, and doing a complete flush of the brake fluid. I had a similar problem to yours on our Outback wagon. Wife pulled into the driveway one day with smoke pouring from the font wheel wells. I replaced the master cyclinder & that fixed the problem. I suspect one of the seals in the master cylinder fell apart or hung up and would not allow the pressure in the line to bleed off, thus keeping the pad in hard contact with the rotor.
