why is the sliding door lock not working automatically anymore? 05 caravan
I've got an 05 caravan and the power lock on the driver's side sliding door quit working. it still works manually, but that's it. any suggestions?
RE: why is the sliding door lock not working automatically anymore? 05 caravan
On the inside latch assembly there is an electronic module that quit working. I've replaced my right sliding door unit once already and it's gone again. The kids pulled on the handle at the same time that I unlocked it.
Do you have to change the whole mechanism or just the solenoid?
Is it easy to replace? |
Need to replace the door actuator, its a little bit of work to replace.
it happened recently on my passenger side sliding door. is there a DIY available to r&r? thank you.
Originally Posted by chuckb
(Post 1269400)
You need to remove the sliding door inside trim panel, etc. to get to the lock. It is fairly straight forward in you are used to removing door panels and fixing things inside. |
thanks. it seems pretty straight forward. i'll take plenty of pics during disassembly.
Don't buy a whole new module! Just buy a new motor
You can buy the little motor inside the module for about $6 and it will work perfectly again! I just did this on my van, same symptom, same door, works perfect now! Saved over $80 on the part. Here's one on ebay: http://cgi.ebay.com/Mabuchi-FC-280-M...item4cef5f467b
great idea!
Our passenger door has the same problem -- I'll be interested in your experience and pictures...
