03 Dodge caravan rattle
Old May 1, 2008 | 06:39 PM
chetc's Avatar
chetc
Default 03 Dodge caravan rattle
We have an 03 Dodge Caravan since new, after about 2-3 yrs this rattle started in the front end, I searched the bottom of the van 5-6 times, can't find anything, other forums said to check the sway bar and the linkage, nothing wrong, sometimes I can over a set of tracks and the rattle is very quiet, sometimes it is loud, sounds like a bunch of pipes rattling, sometimes I can go over a small object or a uneven bump in the road and it makes the rattle, with the hood open I can push down on the van numerous times and it is quiet, this is puzzling me, someone said it might be a strut mount, didn,t check that yet, any ideas.
thanks
Chet
Old May 1, 2008 | 07:23 PM
chopper's Avatar
chopper
Default RE: 03 Dodge caravan rattle
The innards to the catalytic convertor could be loose and causing the noise.A heat shield on this same part could also be loose and can cause the noise you have.
These are a "tinny" sounding noise compared to a more heavy clunking noise caused by front-endor frame parts coming loose.
Old May 23, 2008 | 11:39 PM
buganddoug's Avatar
buganddoug
I would bet it is the sway bar bushings ( bushing to sway bar to frame).
Old May 24, 2008 | 04:22 PM
happyreefer's Avatar
happyreefer
Look at the shock bolts, or rear track bar bushings as well.
