Grand Caravan 2005 Stow & go A/C problem
Old May 17, 2008 | 02:35 PM
libedavi's Avatar
libedavi
Junior Member
Default Grand Caravan 2005 Stow & go A/C problem
Hi, My grand Caravan's A/C is not working Charge is OK, Pressures are ok,low 30, high 250 and cycling but blowing warm air. Can any body tell me whats the problem.
Thanks a lot. Any help is highly appreciated.
Old Jun 29, 2008 | 08:51 PM
gasfitter's Avatar
gasfitter
Default RE: Grand Caravan 2005 Stow & go A/C problem
Are you getting a trouble code?
Old Jun 30, 2008 | 07:21 PM
HemiMan02's Avatar
HemiMan02
not sure if you have rear ac or not but check to see if the rear blows cold and the front hot. most likely it is a mode actuator. have the vehical running and switch the hot cold **** from all the way cold to all the way hot and listen for a change in air movement noise.
(if your not sure what im talking about try it in a known good vehicle first). if your not then you have one of 3 problems, bad control head, bad actuator, or the door has spun past its stops.
Old Jul 30, 2008 | 09:30 PM
libedavi's Avatar
libedavi
Junior Member
Thanks for all the help A/C Working properly now.
Old Aug 6, 2008 | 12:47 AM
sprocket1200's Avatar
sprocket1200
libedavi,
we are having problems too. what did u do to check your and fix it? can u give me details as to how you got access to the system and what u saw?
Thanks,
Cory
Old Aug 6, 2008 | 08:25 PM
libedavi's Avatar
libedavi
Junior Member
Actually I just make sure that I've got the right charge. I think its 3+ lbs because I've got a rear A/C. It says on the hood anyway how much you can charge.
I removed everything evacuate it (Vacuum Pump) and charge with the right amount of 134A. There you go it runs well.
Old Jun 12, 2011 | 06:53 PM
cechowning's Avatar
cechowning
I am having the same problem. A/C Blows HOT air the compressor never cycles any suggestions? Wife is Hot so I am in Hot Water Help!
