Pinhole in Radiator Need Advice Please
Old Jun 7, 2011 | 06:00 PM
dogsofwar37's Avatar
dogsofwar37
Default Pinhole in Radiator Need Advice Please
I have a 1995 Dodge Caravan Se 3.3 V-6 4-Speed Automatic
I noticed this morning...That the radiator has a small size pinhole in it...And it is peeing antifreeze lol...Does anyone know of away i could seal it and it still be able to hold...With that kinda heat and pressure behind it ?...I have called around and can get another one for $140...But it would be nice...If i could just seal it someway...With it just having a pinhole...Thanks
Old Jun 7, 2011 | 08:37 PM
steak59's Avatar
steak59
depends on where is it at, pictures? you can try Epoxy or JB weld product.
whatever u do, do NOT use Stop-leak bottle, it will **** up ur engine or heater core, depending on the amount u put in.
Old Jun 7, 2011 | 09:44 PM
multimedia51's Avatar
multimedia51
For a pinhole I would go with Irontight, follow the instructions and never use more then one bottle. I had a severe leak in the top of the rad and this stuff worked fine. Going on 6 mounths now with no issues. Look for the video on youtube. Aslo to note: Chrysler dealership said it was a head gastket leak, I ignored it and found this stuff. $15.00 or $1500.00 hmmm no brainer. Also to note that when I brought it there for and oil leak they also said Head Gasket. Once again said $1500.00, I said no thanks and brought it for second opinion and it turns out that it was only a valve cover gasket. Hmmm and you wonder why are economy suffers. Sorry to get off topic but compare your cost and hope this helps.
Old Jun 8, 2011 | 11:01 AM
papaduck's Avatar
papaduck
If the hole is located so that you can be easly got to it. Drain and/or remove the radiator and solder it.
Old Jun 9, 2011 | 06:58 AM
dogsofwar37
Well it seems to be leaking where there is plastic...So i am not sure if...JB weld will hold up ?...But im gonna try it.
Old Jun 9, 2011 | 06:01 PM
hemi4spd's Avatar
hemi4spd
if its in a tube you can always solder it shut. Old school days we'd cut the tube and fold/crimp the ends shut.
if its in the plastic tanks, find out what type of plastic they are and use appropriate glue.
Old Jun 11, 2011 | 04:34 PM
dogsofwar37
It seems to be in the plastic...Do you think...JB weld would seal it?...It isnt running hot are anything...Just getting everywhere...lol
Old Jun 12, 2011 | 09:57 AM
RickMN's Avatar
RickMN
Permatex makes a kit for fixing plastic tanks. Scuff up the plastic and apply a fiberglass patch ( in the kit) and apply the adhesive. Can't solder the tubes--they're aluminum.
Old Jun 12, 2011 | 06:22 PM
hemi4spd's Avatar
hemi4spd
i wouldnt put as much faith in the JB as i would in a Resin
solder aluminum?
http://www.youtube.com/watch?v=OLvDH...eature=related
Old Jun 12, 2011 | 09:44 PM
me0418840987's Avatar
me0418840987
If it is a true "pinhole" in a tank, or dead center in a fin, I have in the past ran a rubber washered sheet metal screw (Woodgrip) that is used for metal roofing in the hole, and sealed the leak. That was 3 years ago on our 84 Dodge 350 dump truck, and it is still holding. If it is a tear, or bad seal between tank, and fins, get it fixed or replace it. It will save you a headache in the long run.
