97 grand caravan help
Old May 27, 2008 | 08:36 PM
pgprice29's Avatar
pgprice29
Default 97 grand caravan help
My van will not stop squeaking loudly. It goes squeak squeak squeak and does it constantly. Step on the accelerator and it does it faster. I replaced the idler pully thinking that may of been it. It stopped for a couple of days then started up again has not stopped. Any Ideas?
Old May 27, 2008 | 10:31 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: 97 grand caravan help
What size motor do you have? And have you try running the engine with the fan belt off?
Old May 27, 2008 | 10:57 PM
pgprice29's Avatar
pgprice29
V6 3 liter. no I havent. Sound of the squeaking sounds like it is coming from one of the pullys or the alternator pully. hard to tell
Old May 27, 2008 | 11:07 PM
master tech
The early 3.0L had a water pump squeak only after the engine got hot. But when it was cold, the engine ran fine. no noise. The cause was the seal on the water pump blade.
Old May 28, 2008 | 12:17 AM
pgprice29's Avatar
pgprice29
It does it as soon as the van is turned on and keeps doing it until the van is turned off.
Old May 28, 2008 | 10:03 AM
master tech
Take the fan belts off and start the engine. That will tell you the problem is a belt drive problem.
