hello
Old Jun 15, 2008 | 08:50 PM
spat's Avatar
spat
Default hello
testing! I keep trying to reply to an old thread and no luck then I reply to a recent thread no problem. Try to start a new thread with info copy/past from old thread no luck. what the #$!%#$% is up?
Old Jun 15, 2008 | 08:51 PM
spat's Avatar
spat
Default RE: hello
well that went through. I am confused???
Old Jun 15, 2008 | 08:59 PM
spat's Avatar
spat
Default RE: hello
https://dodgeforum.com/m_1042730/mpa...tm.htm#1055979
Old Jun 15, 2008 | 09:06 PM
spat's Avatar
spat
Default RE: hello
is there are problem with copy and past on this forum?
Old Jun 15, 2008 | 09:10 PM
spat's Avatar
spat
Default RE: hello
I have replaced fuel filter. left it in a shop for three days and they couldn't figure it out. They did get it to stall but every time it would throw a different code if at all. They suggested possibly a bad PCM. Too much money for guess work!
Old Jun 15, 2008 | 09:30 PM
spat's Avatar
spat
Default RE: hello
Yep! apparently there is a problem with copy and past on this forume. At least on my end, never had that problem anywhere els.
Old Jun 15, 2008 | 09:35 PM
spat's Avatar
spat
Default RE: hello
nope thats not it either!
What the $%&&^%#&#$ is wrong with this forum tool
spat's Avatar
spat
Default RE: hello
Ok, anyhoo!
Last night the stalling was very persistant. I stopped at a store for about 3 minutes. Had no problems on the way there. I was only about 3 tenths of a mile from the house.
Old Jun 15, 2008 | 09:36 PM
spat's Avatar
spat
Default RE: hello
When I got back in to start the van it kept stalling imediatly. I finally slammed it into gear while holding the brake and throttle and limped home like a 2 legged dog. When I got out I noticed the smell of hot metal.
Old Jun 15, 2008 | 09:37 PM
spat's Avatar
spat
Default RE: hello
I was quit familliar with the particular smell so I looked under the van and sure enough the catylitic converter was cherry red. I noticed it felt as timming was drastically retarded. That would explain the hot exhaust. That was the first time it did that.
