HELP with 1997 V6 3Liter
Old Jun 25, 2008 | 10:42 AM
pgprice29's Avatar
pgprice29
Default HELP with 1997 V6 3Liter
The van smells like it is burning rich. Could it be the oxygen sensor? Or could it be something else. Also, my backup lights do not work. Replaced bulbs still did not work. Checked fuse and it was fine. Iam stumped. Please help me.
Old Jun 25, 2008 | 11:41 AM
TJeepman's Avatar
TJeepman
Default RE: HELP with 1997 V6 3Liter
Have you checked the computer fault codes for possible diagnosis? See http://www.allpar.com/fix/80s-codes.html
Lights: Could be the switch or a bad ground ppssibly. Do you have a test light and a piece of electrical wire?
Old Jun 25, 2008 | 12:07 PM
pgprice29's Avatar
pgprice29
I will have to check the codes when I get off of work. How does the test light work? Is it something you have to buy at a auto parts store?
Old Jun 25, 2008 | 10:12 PM
master tech's Avatar
master tech
Site Moderator & Tech
You could have a problem with the trans range switch ( TRS ) or an open curcuit to the back up lamps.
Old Jun 30, 2008 | 07:27 PM
46FD04's Avatar
46FD04
Had same problem with backup lights on my 97 3.0L Caravan in April.
After messing around with the shifter linkage for a couple of hours, trying to get the lights to stay on (they'd come on and then go out), I finally bought a new b/u light switch from the dealer and installed it.
The b/u lights are fine now.
The switch is on the front of the transmission, driver's side.
You will need a box wrench to get it out, I forget the size needed.
It is very easy to change.
Good luck.
