transaxle oil seal replacement
Old Jun 28, 2008 | 06:45 PM
shn_lck's Avatar
shn_lck
Default transaxle oil seal replacement
I have sprung a major leak!! The tranny fluid seems to be comming from inbetween the transaxle and the motor, out from under the torque converter cover. Any good tips on how I can repair this myself? I know my way around a rear wheel drive tranny but where do I even start on this???? If it were me I would sell it fast but I just bought the @#$% thing three weeks ago from a company I used to work for and have put many miles on it while the company was running,just my luck. Can anybody help walk me throught this??? Thanks in advance.
Old Jun 29, 2008 | 10:26 AM
deezozdodge's Avatar
deezozdodge
Default RE: transaxle oil seal replacement
GO TO WEBSITE www.ehow.com click video tab then type in cv joint or halfaxle or something similar to what you are tying to accomplish. Could be a seal loose, but the video will probably give you some insight...
Old Jun 29, 2008 | 10:55 PM
shn_lck's Avatar
shn_lck
good info. Thanks, it is a good start to getting this job done,looks pretty straight foward just needed a little guidance to get started. the unknown was what had me a little spooked. Thanks again, I just can't see spending the$$$ for something I can do myself with a little help from this site. This was my 1st. time on this site and so far it's 100%
Old Jun 29, 2008 | 11:03 PM
master tech's Avatar
master tech
Site Moderator & Tech
The front pump gasket of the transmission maybe leaking. The transmission would need to be removed and inspect.
